regular sbc timing chain with elec. water pump?
Old Jul 7, 2004 | 08:54 PM
1badasZ's Avatar
Question regular sbc timing chain with elec. water pump?
can you use a regular sbc double roller timing chain when you run an electric water pump. if so does anyone know what brand and what part number to use?
Old Jul 7, 2004 | 09:03 PM
97WS6SCharged's Avatar
It should be Cloyes 3145. You'll have to grind on the timing cover though.
Old Jul 7, 2004 | 10:36 PM
IrocSS85's Avatar
the diff. is the splined center hole that drives the opti. wanna knw how I now? cause I did a cam swap for a guy and he got me timing gears/chain from auto zone and they gave him the old style gears that dont have the splines. so when I went to install the opti, there wasnt anything to line it up with/in.
anyways, I went with a cmotorsports true roller chain for $70. and yes, yo need to clearance the timing cover a little for the upper part of the chain.
Old Jul 7, 2004 | 10:48 PM
I had to grind down the cam and crank seal area on my cover. I also completely ground down the hole for the water pump drive and tig welded a freeze plug into the hole. No leaks from the front of the motor yet. The back is another story though.
Old Jul 8, 2004 | 11:36 AM
speedmiser's Avatar
That's only with the 92-94 LT1s though. The later models with vented optis dont have the splined hole
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
