reducing knock sensitivity on a 93
Old Apr 24, 2003 | 10:54 PM
bachehbad's Avatar
Has anyone done this??? i could use some help!!!
Old Apr 24, 2003 | 11:16 PM
KCFormula's Avatar
run a search. the '93s are less sensitive, so you shouldnt need to. I didnt.
Old Apr 24, 2003 | 11:40 PM
neil350's Avatar
http://www.charm.net/~mchaney/knock.gif
Old Apr 25, 2003 | 12:29 AM
Mr.Whitey's Avatar
Just in case you didn't know about this site, it good for the 93s.
http://sdf.mogmhp.com/
Old Apr 25, 2003 | 01:33 AM
bachehbad's Avatar
wow both really great sites thanx guys, i also found http://www.geocities.com/MotorCity/6647/ta93/knock.htm for any future searchers.
But the reason i am doing this is because i just installed a cutout and i am getting majour vibrations from the deep rumble, i am really afraid this is causing false knock, i never use octane below 91 and for the past 3 weeks since fuel prices have been low i have been using 94 octane only. So i doubt i would have any real knock!
Old Apr 25, 2003 | 01:36 AM
bachehbad's Avatar
oh one more thing, is there anyway i can find the resistance of the knock sensor without going out and buying an ohm meter??
Old Apr 25, 2003 | 10:01 AM
bachehbad's Avatar
i can't figure out where my knock sensor is! can someone tell me what it looks like and exactly where it is???
Old Apr 25, 2003 | 10:06 AM
madwolf's Avatar
Knock Sensor... (shoebox's picture)
Old Apr 25, 2003 | 10:11 AM
bachehbad's Avatar
nice thnx, ok i think i have found the blue wire, its in one of them wire coduits, but just to make sure i dont cut the wrong thing can you tell me what other wires are in the conduit with it so i know if i opened the right one?
Old Apr 25, 2003 | 12:24 PM
bachehbad's Avatar
ok lifted up the car5 and found the right wire! Does it take some time for the timing to go back to normal after the mod is done?
Old Apr 25, 2003 | 12:38 PM
madwolf's Avatar
There should only be one wire going to the knock sensor, and the timing should adjust right away. When it is pulling timing if it detects knock, it does it only for as long as it detects knock and then immediately goes back to normal.
Nayr
Mar 3, 2023 08:34 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
