reconnecting the EGR pipe
Old Nov 17, 2014 | 04:55 PM
thenewkid's Avatar
I'm having a hard time connecting my EGR pipe back to my short tube header. Its only one bolt but is a nightmare to install. It also doesn't help that the trans. tube Is mounted right behind the bolt. It seems to be almost impossible to do from the top. How does everyone else normally do this?
Would removing the starter help?
Old Nov 17, 2014 | 07:34 PM
Re: reconnecting the EGR pipe
Did you try connecting the EGR tube to the header primary first, then push the other end of the EGR tube over the intake manifold studs.
Old Nov 18, 2014 | 12:24 AM
thenewkid's Avatar
Yeah now that I think about it im pretty sure that's what we had to end up doing a few years go. its just unfortunate if that's how it has to be done. my exhaust gaskets went on almost perfectly. I can get an 1/8 of a turn with a wrench when im under the car but its not the most comfortable. How tight does the bolt need to be?
Old Nov 18, 2014 | 09:00 AM
With only one bolt holding it, the bolt needs to be very tight. A leak at that location will screw up the O2 sensor reading.
I have an aluminum blanking plate, and I added a thick steel plate on top of it, plus a lot of RTV to insure no leaks, with the bolt as tight as I could get it. Fortunately, mine appears to be a lot easier to access.
Old Nov 18, 2014 | 12:22 PM
thenewkid's Avatar
Who makes those headers? That looks much easier than mine
Old Nov 18, 2014 | 12:57 PM
Those are AS&M (Arizona Speed & Marine) mid-lengths.
My A/C is deleted, so less stuff in the way. The trans is a TH400, so the Lokar flexible dipstick is out of the way on the aluminum bracket held by the last centerbolt on the valve cover.
generaldave
Sep 25, 2015 06:48 PM
Pwilson59
Sep 3, 2015 08:47 PM
surreybrad
Aug 10, 2015 09:34 AM
Devinfoote87
Jul 30, 2015 09:54 AM
Jlo
Jul 29, 2015 03:52 PM
