Recommend some 3" (copper?) collector gaskets
Old Apr 1, 2005 | 10:37 AM
madwolf's Avatar
My header to y-pipe gaskets are leaking and I would like to get some better gaskets. Let me know what you've had good luck with and where you bought them from.
Thanks.
Old Apr 1, 2005 | 10:41 AM
Black95Form's Avatar
Re: Recommend some 3" (copper?) collector gaskets
Copper will leak like a siv. Atleast that has been my experience.
Old Apr 1, 2005 | 10:44 AM
madwolf's Avatar
Someone recommended copper ones before, that's why I mentioned it. I also thought they would leak in that spot. Any other suggestions? Go with paper again?
Old Apr 1, 2005 | 11:04 AM
BA383TA's Avatar
I've had good luck with Percy's dead soft aluminum gaskets from Summit.
Old Apr 1, 2005 | 11:05 AM
sssalah's Avatar
I'm using summit aluminum gaskets on both my cars, reused them several times never leaked.
Old Apr 1, 2005 | 11:09 AM
Ricardo's Avatar
I went thru two sets of aluminum collector gaskets and they practically flowed out of the flanges where the bolts were not keeping them in place.
I switched to copper gaskets about 1 1/2 years ago and they seal perfectly.
Old Apr 1, 2005 | 11:20 AM
turbo_Z's Avatar
I have those and would say they work good. Had to pull them out the other day to replace header gaskets and noticed the collector gaskets were sealed perfectly. Now the Percy dead soft aluminum header gaskets didnt work out so great.
Old Apr 1, 2005 | 11:30 AM
madwolf's Avatar
Yep, that's what I'm gonna do today. I'll be retightening them for the 2nd or 3rd time now. (Percy's header)
Old Apr 1, 2005 | 11:51 AM
BlownF1's Avatar
We tried aluminum ones too...worthless. IMHO, your best bet is to get the regular Fel-pro paper ones and buy some better fastening hardware. A buddy of mine was told by an exhaust shop that the secret is to NOT use hardened bolts, just get regular ones and some "crush nuts". The bolt needs to stretch slightly and the crush nut will keep it locked there. He was replacing gaskets frequently and it's worked great for him since.
Jeff1904
Jun 5, 2016 05:00 PM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
Pwilson59
Sep 3, 2015 08:47 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
