Recipe for a 11 sec n/a street car?
Old Jul 12, 2004 | 07:52 PM
Baby Bird's Avatar
well i got me a new toy to play with. Its a 94 formula red with black interior and all the bells n whistles. I used to have an 85 t/a that i missed so i went out and got myself another. I used to have some quick cars back in high school, but money got tight so i had to stop for a while. I fell into a lil cash and want to make a car i can be proud of out of this. Ive been looking at this site and ls1 and 2 dot com and have an idea of what i want and was wondering what you all thought of my plan. Heres a list of what im looking to get, and id like to get it into the high 11s at least without any kinda nitrous or anything.
Hooker long tubes, coated, and a hooker catylitic converter back system
A vigilante or yank 3200 stall
lloyd stage 2 heads with a custom cam from him
lt4 timing chain
and im looking at a moser 9 inch rear axle with 3.73 gear
slick tire
them lt4 knock sensors
and im still looking for a place to give a good tune here around lexington
anything else you boys might suggest would be appreciated. Any ideas what this will cost if i do all this work with my brother, hes a mechanic and owes me a whole lotta favors so labor is free.
Old Jul 12, 2004 | 07:54 PM
Somnambulist's Avatar
LE3 package (only a couple hundred more than the LE2)
full exhaust
solid rear end
sticky tires
full valvetrain
rebuilt trans
BIGGER stall
some aftermarket suspension
...and all the smaller stuff I forgot!
Old Jul 12, 2004 | 07:56 PM
Baby Bird's Avatar
what alls in a lloyd 3 heads?
Old Jul 12, 2004 | 08:08 PM
LE3 cam pulls from 2600 to 6800 RPMs in a 350 (2300 to 6500 in a 383) and should make 410 to 430 RWHP with matching heads (heads are ported and machined for larger Ferrea 2.00/1.56 valves Comp 977 dbl springs, titanium 10* retainers, locks, locators, milling, cleaning and assembly), 36-42lb injectors, 58mm TB or mono blade, GOOD tuning, etc. These com with the Comp 977 springs. Comp R lifters are also advised.
Heads and cam are $1700. This cam is similar to the GM 847 but makes about 10 more HP at peak and starts making HP sooner. Makes more HP and TQ across the board. Definitely needs gears and converter to work well in the 350.
Old Jul 12, 2004 | 08:24 PM
btw, this is a Joe Overton cam. He no longer produces cams for the general public, only for Lloyd and one other guy...
Old Jul 12, 2004 | 09:51 PM
97 RedSS's Avatar
Mine is driven daily and runs 11's..
Cody
Old Jul 12, 2004 | 10:18 PM
formula383's Avatar
le2 heads and cam and the other supporting mods you listed should get you there with good tuning and good driving.
As far as tuning goes I am going to take mine to Jeff Creech at Carolina Auto Masters when I go with a different setup. I have heard good things about LT1 Dave as well and he is closer to you, he is in Cincinnati I think.
Old Jul 12, 2004 | 11:12 PM
kgkern01's Avatar
Brent at TEA (Total Engine Airflow) in Bowling Green does some excellent tuning down there, as well as CNC heads and heads/intake/cam combos. They are highly recommended on the local KY Fbodies Unlimited Board . A lot of guys on our board can help you out as well.
I would say a strong rear, DR or slicks, good heads/cam/valvetrain combo, and slightly higher stall TC would put you there without much trouble. My friend is running a 4000 Yank stall in his intake/exhaust LS1 A4 98 TA and it is still very easily street driven.
Old Jul 12, 2004 | 11:54 PM
1982z28with18s's Avatar
See sig. It's my daily driver, 80 miles/day and gets 21-22mpg
Old Jul 13, 2004 | 01:36 AM
DrewHMS97SS's Avatar
Originally posted by 1982z28with18s
1997 Formula, stock bottem end, Lloyd Elliot ported heads and intake, SMALL Joe Overton cam(~220/226), 3000 stall, 3.73's, 30lb injectors, pcmforless tune, jet hot long tubes, all the other little stuff....
11.710 at 116.76 in 2350DA ALL MOTOR
always showin off
Old Jul 13, 2004 | 01:56 AM
Kain's Avatar
Originally posted by DrewHMS97SS
always showin off
~*HoLLa!*~
Old Jul 13, 2004 | 02:01 AM
:P
Old Jul 13, 2004 | 02:03 AM
Kain's Avatar
:P
I'm going to be going considerably slower though when I swap out to a 6 speed... and turn my car into a road race car.
Old Jul 13, 2004 | 02:44 AM
mastrdrver's Avatar
Lose as much weight as you can live with. Frank95Z did that, and with the Crane 227(210/224) and stock heads ran 11s. That was with an auto.
Old Jul 13, 2004 | 02:49 AM
Next time around I'm going after your time first night out Kain. Gotta bump ya down on the list.
