Rebuild or Replacement?
Old Dec 21, 2007 | 10:57 AM
Mortify's Avatar
Well I had been having electrical problems all summer and just as the season was coming to a close my alternator finally showed its true colors and failed on me.
It had been suspected because of constant high pitch feedback coming through my speakers only when the engine was on, and would increase in volume as the RPMs climbed. (I have a 1600W system with 2 x 12" JL Audios, caps.. show car quality)
Now I can get my alt rebuilt here for $100, and for an additional $35 it can be upgraded to pump out 140amps instead of stock (I think 100amps?) OR I can pick a stock alternator off the boards here for around $30 + shipping.
I know I would be risking a future failure of the stock alt but $30 is hard to pass up. Opinions?
Old Dec 21, 2007 | 04:43 PM
96' Formula WS6's Avatar
If the guy who is rebuilding it will warranty the warranty then i say go for it. if not i wouldnt and plus is there any visible way to tell that an alternator has been upgraded.
Old Dec 21, 2007 | 09:17 PM
greenmachinedriver's Avatar
i would go with the rebuild or posibly the high output aftermaket ones, due to the aftermarket sterio. also the way your amplifier is grounded can affect the way it will pick up ignitipn or alternator interference. if it does not go away after the new alternator you might look into it.
Old Dec 21, 2007 | 09:39 PM
OBE1 95Z28's Avatar
Take a look at these: http://www.powermastermotorsports.com/high_amp.html
Sergio
Jan 27, 2016 04:27 PM
Jazsun
Dec 29, 2014 12:14 PM
chuyz28
Nov 25, 2014 11:14 PM
