Reasons for dropping oil pressure?
Old Jun 13, 2003 | 11:22 PM
  #16
IrocManiac's Avatar
Originally posted by Kuma
According to my sources, your oil pressure is spot-on. According to Lingenfelter's book, any small block chevy with a functioning lubrication system will get about 5-10 psi per 1000 rpms. Higher oil pressure is not necessarily better, nor does it mean more oil FLOW, it really just means that the oil pump has to work harder because the oil is more viscous. REALLY HIGH oil pressure is not a good thing performance wise since you are losing more power parasitically to spin the pump.
And yes, I agree with the others, it comes down after a while, after the oil heats up, because it thins out due to temperature.
Not only to spin the pump but thicker oil causes more drag on the motor...not much, its not hardly even noticable but it does.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
