rear view mirror
Old Jul 29, 2003 | 09:45 PM
windnsea00's Avatar
Question rear view mirror
i accidently yanked off my rearview mirror and was wondering if i should use an adhesive to have it stick back to the metal plate on the window, if so what type. thanks for any help.
Old Jul 29, 2003 | 09:52 PM
CoUnTryMuZiCZ28's Avatar
ANY adhesive you use will melt in the sun and when you get back to your car the rear view mirror will be alying on the floor. I suggest just replace it.
Old Jul 29, 2003 | 10:27 PM
Donny O's Avatar
so you pulled the mirror off of the metal button that is stuck to the windshield? or did you pull the whole thing off?
if the metal button came off they make kits to stick it back on....cost like $2 and takes like 5 minutes to fix. if you broke the plastic of the mirror then jsut get a new mirror!!
FYI some usless info for you....the place I worked while in college made those metal mirror mounts. they are made from compressed powder stainless steel....made on a 100 ton press, then ran through a sintering furnace. place is in janesville wisconsin and called SSI Technologies....sintered specialties division. also make gears for saginaw, and the metal things that went in the pasta makers you could buy at the store, and little magnets thatwere very strong and various other parts but mostly mirror mounts. thousands a day I would make.
Old Jul 29, 2003 | 10:49 PM
windnsea00's Avatar
the metal is still stuck to the window, where do u find these kits to get it to stick back together?
Old Jul 29, 2003 | 11:12 PM
Donny O's Avatar
if the metal is still stuck then the mirror should jsut slide back on unless you broke the plastic then you will need a new mirror. as for the kits to stick the metal thing back to the window they can be found at any auto parts store, or even walmart in the auto department.....but it doens't sound like you need that!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
timmy39120
May 2, 2015 05:12 PM
Fatdog2
Jan 24, 2015 12:08 AM
Red97LT1
Jul 28, 2002 06:37 PM
