rear/front rims will not interchange??
Old Jan 27, 2003 | 05:34 PM
pearlpurple's Avatar
I have a 92Z with the five spoke 97 rims. (No salad shooters for me)
Anyways went to get two new tires for the rear today. I tried rotating them months ago could not get the fronts on the back so I just wore the backs out. Tire shop kind of kidded me today when I told them they would have to re mount the fronts on the back as they did not believe me. Any ways why is this the case?? Back rims only on the back/front only on the front??
Oh by the way bought two Kumhos (Esctas or something like that) 245/50/16?? Any good got 2 for $163 installed also with the extra two mounts and dismounts for the stupid rims?????
Thanks for any replies
Old Jan 27, 2003 | 05:47 PM
sandmanljs's Avatar
Did you have diffrent size tires and/or wheels on the rear?? Thats the only reason i can see that they would have to do that. Ive roatated f-body wheels before with no problem.
Old Jan 27, 2003 | 05:48 PM
I don't quite understand that since the 97 wheels are the same for all 4. I know that the 3rd gen wheels are different front and back and that is why you cannot rotate them. But if you are using the 4th gen wheels that are the same all around, why could you not rotate them? I must be missing something. Have the 4th gen wheels been modified?
Old Jan 27, 2003 | 06:33 PM
ky94transam's Avatar
Newer style wheels have a diff.inner diameter.You will have to have the inside of the wheels turned on a lathe.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
