Rear end swap out questions
Old Mar 21, 2004 | 12:36 PM
1msfyter's Avatar
Freind of mine offered me his 02 rear end -complete brakes etc.
His SS has traction control and ABS. My 95 has ABS but no traction control. I know the rear end will bolt right up, but Im concerned about the wiring for the abs and TC. Will there be problems?
Old Mar 21, 2004 | 06:08 PM
slopokrodrigez's Avatar
ABS uses 3 sensor inputs and traction control uses 4. You could use one of the rear wheel sensors as your new rear differential signal. Should be real easy to do since the wheel sensors on the TC system use the same connector as the differential sensor on the standard ABS units. Just simple pin changes should take care of the problem.
oldschool
Feb 9, 2016 09:21 PM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
FredM
Dec 18, 2014 01:40 PM
