rear end setup question
Old Oct 21, 2003 | 09:04 AM
25thAnnTA's Avatar
Puttin in the new"er" differential tonight. Does anyone know where the pinion depth and such should be set to? backlash?
Old Oct 21, 2003 | 09:53 AM
1Z2Z's Avatar
http://www.bfranker.badz28.com/fbody/guides.htm
Install guide here may help. It is what I used to do mine.
Not sure on pinion depth but I can tell you that you will want to keep backlash on the tight side. For example if the tolerance is .005 - .012, shoot for @ .007. Mike
Old Oct 21, 2003 | 12:27 PM
thermwood1's Avatar
It really depends on what all you are replacing (carrier, gears-gm or aftermarket). If you are using aftermarket gears, the pinion depth is marked on the pinion gear. Good luck if you have never done this before.
Old Oct 21, 2003 | 01:32 PM
25thAnnTA's Avatar
having an experienced friend help me out. replacing diff unit with zexel, have existing richmond 3.73's.
Old Oct 21, 2003 | 01:54 PM
thermwood1's Avatar
Your pinion will remain the same. You don't even need to take it out. All you have to worry about is the backlash on the ring gear. Should be pretty easy.
oldschool
Feb 9, 2016 09:21 PM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
