rear end setup question
http://www.bfranker.badz28.com/fbody/guides.htm
Install guide here may help. It is what I used to do mine.
Not sure on pinion depth but I can tell you that you will want to keep backlash on the tight side. For example if the tolerance is .005 - .012, shoot for @ .007. Mike
It really depends on what all you are replacing (carrier, gears-gm or aftermarket). If you are using aftermarket gears, the pinion depth is marked on the pinion gear. Good luck if you have never done this before.
oldschool
Feb 9, 2016 09:21 PM
