Rear end question
Old Aug 28, 2004 | 08:16 PM
corkss's Avatar
Rear end question
I recently changed the rearend fluid in my z, i got some oil on the filter when replacing it causing a slow leak i noticed after sitting a couple days, question is, when i put a new cover on , the magnet wasn't glued , it had broke off, when i put the cover on i didn't put the magnet on, when i replace the fluid next time, shortly, what should i usee to glue that magnet on and make sure it will stay on throught the heat of the rearend, or doesn't the magnet matter much.
Later
Old Aug 28, 2004 | 09:31 PM
n2ceptor's Avatar
Re: Rear end question
Yes, the magnet matters.... It pulls metal out of the fluid.... As for glueing back on, clean the cover with brake cleaner, then soap/water.. Dry and I think 3M part #08001(aka; gorrila snot) might hold it in place.....Not sure though...
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
