rear end help!!!!!!
Old Sep 2, 2003 | 03:45 AM
SiDeWaYZz28's Avatar
rear end help!!!!!!
ok the problem is my rear end is leaking but its leaking in the front next to the a arm not in the back of the houseing.... and i need to know what gasket i need or how to fix this leak b4 my rear end leaks all its fluid and my rear end freezes up on me........thanks
for takeing the time to
check out
what i had to say
Old Sep 2, 2003 | 08:12 AM
thermwood1's Avatar
If it's leaking up by the driveshaft, then it's your pinion seal leaking. This could be caused from the seal being bad or possibly a bearing going out. Is there any kind of noise coming from the rearend? Any kind of a whine or anything? If so, then you have a bearing going out, if not then you might get away with just replacing the seal.
Old Sep 2, 2003 | 01:54 PM
Sweetred95ta's Avatar
Yep the pinion seal, and I'm pretty sure you can do that w/out taking the whole stupid *** rearend apart, just drop the drive shaft.
Benji
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
