Rear end gears/differential- How hard to install for first timer?
Old Apr 18, 2003 | 07:31 PM
gamboa's Avatar
May need new gears and differential in rear end. Something a first timer can do or not? Anyone attempt this as a first timer? How'd it turn out?
Old Apr 18, 2003 | 08:04 PM
FireAm94's Avatar
I wouldn't suggest it. If it's not setup correctly it will fail alot quicker. These rears are too weak as it is.
Thanx
Joe
Old Apr 18, 2003 | 08:08 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Rear end gears/differential- How hard to install for first timer?
you need several special tools. this isn't a bolt on thing like headers or anything.
You have to check the back lash and stuff
I wouldn't try it for my first time alone
Old Apr 18, 2003 | 08:31 PM
grendal's Avatar
Not a do-it-yourself job for a rookie... or even an experienced home mechanic. Specialty tools required as well as considerable knowledge from what I've told.
Pay someone to do this one... even the best do-it-yourselfers that I know, don't touch rear-end gears.
-Michael
Old Apr 18, 2003 | 09:48 PM
kjlvilla's Avatar
Unless you have a pinion depth gauge and know how to read a pattern check, I would have someone else do it. A lot of people get by with using the stock pinion shim without a problem but it isn't a sure thing. You also need an arbor press for the bearings and a companion flange holder. The pinion nut torque is very high and crushing the sleeve takes alot of torque. You sometimes have to pre-crush them in a press. If the gearset you get is a GM set, you will also need to check to see if it is a 5 cut (old) or 2 cut (new style) ring and pinion. This makes a difference on the pattern check. The last thing is checking the backlash, this is the easiest step if you get past the rest. Hope this helps.
Old Apr 18, 2003 | 09:58 PM
carnutz's Avatar
I just did this today, not something I lke to do in the garage, PITA, a hoist makes all the differance. Part of my job is setting up gears, not something I would reccomend to a first timer. Pinnon deph and preload aren't easy to establish.
Old Apr 18, 2003 | 10:09 PM
gamboa's Avatar
Thanks for the info gents. Definitely won't be doing it on my own then.So when does one need new gears versus a new differential or a whole new rear end for that matter. I know very little about the rearends on our cars.
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
