Rear end gear
Old May 9, 2004 | 04:41 PM
GMH94Z28's Avatar
Question Rear end gear
I was changing the rear end oil and i looked on the pinion gear and thought i would see what gear was in there and the number on it was 12:41-GM i though it had a 342 gear in it. Does anyone know what gear size this is. I have a 1996 Z28 that had the T56 in it and i put in a 4L60E in it. Thanks in advance
Old May 9, 2004 | 04:44 PM
Nestromo's Avatar
3.42s
Old May 9, 2004 | 04:48 PM
GMH94Z28's Avatar
Nestromo,
How did you get that from that number? I was looking at shoebox's site and the number wasnt the same it was like 13:42. Thanks for the responce
Old May 10, 2004 | 08:33 AM
Nestromo's Avatar
Originally posted by GMH94Z28
Nestromo,
You are thinking 1:3.42, which is commonly just called "3.42". It's sort of like a compression ratio. It could be called 10.5:1, but often people just call it "10.5".
That, plus all '94 6spds came with 3.42s.
Old May 10, 2004 | 09:52 AM
nateh's Avatar
41 ring gear teet, 12 pinion gear teeth. 41/12=3.41667=3.42
You have 3.42:1 gears.
Old May 10, 2004 | 10:43 AM
GMH94Z28's Avatar
Thanks for your help guys
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
