rear end?
Old Jan 5, 2004 | 03:37 PM
takedown171lb's Avatar
rear end?
do i have a 7.5 inch 10 bolt rear end in my 1995 z28 stock camaro
Old Jan 5, 2004 | 03:42 PM
hsyr's Avatar
Unless someone else changed it before you then yes you have that.
Old Jan 5, 2004 | 03:47 PM
so what would i have to buy if i got say 3.73 gears for it?
Old Jan 5, 2004 | 04:02 PM
simple's Avatar
drivetrain section
Old Jan 5, 2004 | 08:23 PM
My95Z's Avatar
depends on if u are auto or manual.. if manual you won't need anything except the gears and install stuff
auto- depends on gear option stock.. if u ave 2.73 you will need a serries 2 carrier, if you have 3.23 performance axel, just need gears adn install stuff
Old Jan 5, 2004 | 10:43 PM
i got an auto w/ 3.23s will i notice a difference with 3.73s or should i go with the 4.10's? thanks
Old Jan 6, 2004 | 08:54 AM
My95Z's Avatar
*EDIT*
if you have an auto with 2.73 gears you will need a series *3 carrier becasue you have 2 now... if you have 3.23 gears, oyu just need to get teh gears and install stuff
Old Jan 6, 2004 | 10:04 AM
ishz28's Avatar
As mentioned above you will need a 3 series carrier. Much thicker then a 2 series carrier. You will also need to reprogram the CPU, for the gears you choose. I went from 2.73's to 3.73's and noticed a 10mph difference between speedo and road speed (had a friend follow me at a set speed.). I choose Pro Street gears and am pretty happy with them.
Old Jan 6, 2004 | 08:42 PM
$hawn's Avatar
7.625, the 3rd gens are a 7.5.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
