Is this really a blown head gasket?
Old Mar 28, 2010 | 01:53 PM
  #16
Slick-Z's Avatar
Well i wouldnt consider it a head gasket anymore after that. I had a problem similar to yours after i replaced my intake manifold. After about two or three miles down the road my car was overheating. I knew the problem in my case it was the fans. whenever i work on my car and put it back together i always have this problem. All i have to do is grab the bracket that contains the fan motors and connects the fans to the radiator and i just shake it around figure its a loose connection but it always seems to work. And another thing about the garage telling you that it would cost more to do a head gasket than just buying a new engine. After i was told that a few times i realized that it was usually inexperienced shops that didnt deal with alot of lt1s so they were just throwing prices out there. I had gm tell me that they would charge me around three thousand dollars for a new distributor and fixing an intake manifold leak. So yeah people out there will difinately try to rip you off. I wound buying the haynes manual and buying a new distributor and installing that one and fixing the intake for around five hundred dollars. Well good luck and it definately sounds like the fans are going out on yeah.
Old Mar 29, 2010 | 06:03 AM
  #17
Guest47904's Avatar
Guest
Originally Posted by gelbza
Today I went out and started it and let it run for about half an hour, drove it for maybe 2-3 miles. The temp gauge never moved off of 100.
Granted, the overheating only happened the one time, right after I got it back from a whole array of repairs (see first post for list). Is it possible that the overheating last year was just a temporary result of those repairs, and that the engine had to work something through it?
It would appear that your engine was merely air bound. Have you checked the fluid level in the radiator when its cold first thing in the morning?
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
