Raytech Solid Pinion Spacer?
Old Mar 8, 2003 | 04:00 PM
oldschool's Avatar
I plan on installing some Nitto dr's and to help my crappy rear-end hold up, I bought a MAC rear girdle. I also heard that the Raytech Solid Pinion spacer helps alot by preventing the pinion from moving around. Has anyone done this, heard of it, or know ANYTHING about it?
I have about 360rwhp in m6 LT1 w/heads, cam and LT's etc. Do you think my rear will hold with the install of the Nitto's?
Andy
Old Mar 8, 2003 | 04:52 PM
Grease's Avatar
I have one in my car. You can buy one from Summit racing for 18$
http://store.summitracing.com/defaul...rchType%3DBoth
Old Mar 8, 2003 | 05:44 PM
It looks like this.
Old Mar 8, 2003 | 05:58 PM
Buttercup's Avatar
It is an excellent piece of hardware to use but it isn't as simple as bolting it up like the girdle. You need to remove the cover, carrier, driveshaft, yoke, seals, bearings, follow a procedure to shim the new solid spacer, and reinstall everything (preferably with new bearings) and recheck/adjust the gear specs.
IndyZman
Oct 22, 2015 02:17 PM
95chwagon
Oct 16, 2015 12:24 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
