Raytech Solid Pinion Spacer?
I plan on installing some Nitto dr's and to help my crappy rear-end hold up, I bought a MAC rear girdle. I also heard that the Raytech Solid Pinion spacer helps alot by preventing the pinion from moving around. Has anyone done this, heard of it, or know ANYTHING about it?
I have about 360rwhp in m6 LT1 w/heads, cam and LT's etc. Do you think my rear will hold with the install of the Nitto's?
Andy
Andy
I have one in my car. You can buy one from Summit racing for 18$
http://store.summitracing.com/defaul...rchType%3DBoth
It is an excellent piece of hardware to use but it isn't as simple as bolting it up like the girdle. You need to remove the cover, carrier, driveshaft, yoke, seals, bearings, follow a procedure to shim the new solid spacer, and reinstall everything (preferably with new bearings) and recheck/adjust the gear specs.
Henson071
Sep 21, 2015 04:31 PM
