Rattles from jethot Longtubes
Old Nov 18, 2003 | 07:44 PM
speed_demon24's Avatar
Does anyone know any easy way to get rid of all the rattles with my jethots? It's only when im stopped or just start accelerating, and most of the rattling goes away if i put the car in neutral when im at a stop. If the only way to get rid of them is to put in poly motor mounts, how hard are they to change out?
Old Nov 18, 2003 | 09:52 PM
$hawn's Avatar
Depends on where yours are touching, new motor mounts might help even just regular rubber ones, mine rubs on the passenger side, one tube is really close to the k member, i'v heard about grinding it some but dont want to do that, plus it'll be hard with it that close, where exactly do yours touch.
Old Nov 18, 2003 | 09:56 PM
b-stevens's Avatar
Ive got that problem with my mac's. It looks to be touching at the k-member as well.
Old Nov 18, 2003 | 10:08 PM
Seal's Avatar
put some headshield thing where it touches... it should stop the metal to metal contact
Old Nov 19, 2003 | 08:45 AM
b-stevens's Avatar
I was thinking about doing that, but arent most sizes for plug wires and small hoses? where should i pick up some that size?
Old Nov 19, 2003 | 09:29 AM
MonoxideChild's Avatar
How many people have issues with the jet-hots rattling?
I just bought them and never heared of this problem!
anyone else?
Old Nov 19, 2003 | 09:54 AM
BitCypher's Avatar
anyone else?
I just installed a set of Jet-Hot LTs on my '96 T/A (94k with original motor mounts) and the closest they get, at any point, to the k-member is 3/4 of an inch. The collectors are approximately 1.25 of an inch from the floor pan. They fit beautifully! I'll snap some pics for those interested.
Old Nov 19, 2003 | 09:59 AM
ibanez6rg's Avatar
Mine were rattling because I dropped a socket and header bolt down into the passenger side collector - Put an end to that
Old Nov 19, 2003 | 10:07 AM
Red96Lt1's Avatar
I would like some pics, I just ordered my Jet Hot's today. Thanks!!!
Old Nov 19, 2003 | 10:25 AM
BitCypher's Avatar
I'll take some tonight when I get home and reply to this topic with a link.
Old Nov 19, 2003 | 10:26 AM
GetaZforgetGT's Avatar
I had a problem with mine rubbing on the passenger side.
I just jacked the car up and placed a few wooden blocks under the transmission to support he engine while i lowered it a little (about two inches) with the jack.
I then took a die grinder and knocked the part of the k member that was rubbing down a little.
You don't have to go crazy you can easily take about a 1/4 inch out where the K member makes the curve down on the back side.
Mine started out being a little noise but slowly got worse.
Safety note, metal shaving fly everywhere when doing this don't forget the goggles. If you have ever had metal in your eye you know what I mean.
Old Nov 19, 2003 | 11:04 AM
T/A#4's Avatar
My car is in the shop having Jet Hot headers installed as I write this. The passenger side header wouldn't install because it was hitting the K-frame. So they cut off 1/2 " & welded a reinforcment piece for strength over the hole. Now there is about .060 clearance. My motor mounts have only 6000 miles on them. This shows that "somebodys" production standards are way off !
Old Nov 19, 2003 | 11:13 AM
yikes! Man, I hope I don't have any of these issues. I have 138K miles on my car. :/
mac headers fit like a champ when those were installed. no rattles. Also, it burnt a #5 wire.
getting heat sleeves for my new wires. ;P
Old Nov 19, 2003 | 11:18 AM
PICS PICS PICS!!!
dmgov@nospam.com
nospam.com = netzero.com
Old Nov 19, 2003 | 04:27 PM
aram's Avatar
my driver side collector is practically touching the floorboard. Brand New ES Motor mounts.
