Ratchet Shifter for 4L60E?
Old Jun 4, 2003 | 10:25 AM
bruecksteve's Avatar
Does anybody sell a ratchet shifter for the 4L60E transmission? I see them for the 7004R but not mine!
Old Jun 4, 2003 | 11:28 AM
No one knows???
Old Jun 4, 2003 | 01:08 PM
RedWolf's Avatar
i've asked this question in the past heres the link:
http://web.camaross.com/forums/showt...hreadid=120711
Old Jun 4, 2003 | 01:27 PM
Thanks! Just checked it out. Looks like the B&M Megashifter should work but I re-asked just to be sure I'm not reading something wrong.
Thanks again!
Old Jun 6, 2003 | 12:32 AM
fbird95's Avatar
I would be carefull putting a ratchet shifter on a 4L60E trans. Manual shifing it with the stock shifter puts a serious hurting on this trans, an actuall ratchet shifter will end it life even sooner.
Old Jun 6, 2003 | 12:37 AM
stevil's Avatar
Yep. Unless you've put in a manual valve body or something, there isn't any reason to shift the gears, the computer does it.
Old Jun 6, 2003 | 01:23 AM
revtime's Avatar
You can,t put a manual valve body in a 4L60E.
PCM controls shifting so you would need a 700R4 or 350 or 400 turbo.
Old Jun 6, 2003 | 01:33 AM
Rich_z28's Avatar
Sure you can. Trans Go sells a manual valve body for the 4L60E.
Old Jun 6, 2003 | 01:36 AM
stevil's Avatar
You could deactivate the PCM control of it, and install a MVB somehow. The 4L60 is similar to a 700R4, I'm sure it's possible.
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
CARiD
Sep 7, 2015 08:21 AM
