RAP or Express Down Module??
Old Feb 20, 2004 | 10:50 PM
LandShark57's Avatar
I replaced the power window motor and switch in my 95 TA and apparently shorted out something else. Now, neither the driver nor passenger side windows work. The radio is also gone. I'm getting no power to the brown wire that connects to the switch.
All the fuses and circuit breakers are good, so could the problem be the RAP or express down feature for the window?
thanks for any help
Charlie
Old Feb 20, 2004 | 10:56 PM
The express down has nothing to do with the radio, but the RAP module does.
Unplug the RAP module and use a fused jumper to jump between "B" (dark blue) and "C" (red) in the harness connector. If the radio and windows work, then the RAP is at fault.
Schematic
Old Feb 21, 2004 | 12:21 AM
So where is the RAP in a 95 trans am?
Is it in the same position as the camaro (under the dash on the drivers side near the center)?
It seems as though this is the most likely culprit for my problem.
Old Feb 21, 2004 | 07:25 AM
Same place.
OutlawPerforman
Oct 30, 2017 05:40 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
Sep 18, 2015 03:46 PM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
