Random Electrical Failure
Old Feb 24, 2007 | 04:26 PM
MEAN LT1's Avatar
It just started happening, I was driving on the highway and all of a sudden just lost all electrical power in the car I mean everyhting shut off. After messing around with the battery termanals I finally got power back but noticed the voltage was down while driving.
Ive replaced both pos and neg battery screw-in's checked and rechecked the starter wires were the battery wires go. Tightned down both grounds on the passenger side. Checked the ground on the head going to the chassis, and replaced the battery. What else can i check?
Old Feb 24, 2007 | 04:40 PM
97WS6SCharged's Avatar
You've obviously angered the car gods in some fashion. Their wrath will be terrible.
You're not still using that negative battery cable that you tried to set of fire, are you?
Old Feb 24, 2007 | 05:03 PM
MEAN LT1's Avatar
I might have to sacrifice an LS1 to appease them b/c they wont stog fuggin with me.
You make it sounds like it was a forrest fire or something , it was just a little "flame". But even so, its been running good and charging fine for this long. I put my battery charger termanals on them and they read fine with no resistance.
Old Feb 24, 2007 | 07:32 PM
MEAN LT1's Avatar
Fixed, it was the pos external post on the passenger side wheel well. The nut was loose.
Old Feb 24, 2007 | 09:21 PM
Too easy.
Old Feb 25, 2007 | 11:01 AM
MEAN LT1's Avatar
Originally Posted by shoebox
Too easy.
Yea, too bad I spent the better part of the weekand going through all the grounds instead of the positive leads. Glad it fixed though, I hate electrical problems.
greenzee28
Sep 25, 2015 04:29 PM
Aaront810
Sep 11, 2015 11:24 AM
damnyankee36
Sep 9, 2015 07:06 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
