ran 12.9 but trapping 112.95mph!
Old Feb 3, 2005 | 10:22 AM
  #16
Tekprodave's Avatar
Re: ran 12.9 but trapping 112.95mph!
Originally Posted by fireman
I have several low 1.8 passes on my 4.10'd 10 bolt with stickies and a 6 spd.
I dump it at 3500rpm and floor it.
I saw a guy at the track with a '95 T/A that looked pretty stock on the outside and it was 2900lbs with driver. He had an old school carbed 350 in it though.
Check sig for my times.
2900 with driver Wow that's light. I've got to add the weight of a cage in mine so it'll be difficult to keep the weight down. Also I weigh 220#.
Old Feb 3, 2005 | 11:04 AM
  #17
Gripenfelter's Avatar
I would say about 12.4-12.5 with a 1.9 if you are running 2.2 right now.
Old Feb 3, 2005 | 11:23 AM
  #18
ksmyss's Avatar
you will be running right around the times in my sig.
i run 4.10s in a stock 10 bolt witha spec stage III and 16" bfg drag radials. i usually leave around 3500 and slip the clutch a little. a little trick is to always keep the drivetrain loaded. i have prolly 50 or so passes like that.
Old Feb 3, 2005 | 03:44 PM
  #19
Quick96Z's Avatar
you live in eagan ScreamnChicken, we should hook up and go drag racing sometime man. Are you apart of the mnfbody club?? As far as my car, i plan on putting her on a little bit of a diet, and just practicing this year (also praying to every god that there is in hoping the rear end will hold together). I am already putting away for a 12-bolt right now so that if she were to let go in the middle of the summer, i wouldn't be completely screwed. I really appreciate all the posts guys..thanks!!
trav
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
95chwagon
Oct 16, 2015 12:24 PM
1bad427ls1
Sep 23, 2015 01:12 AM
