ram air or not to ram air
Old Jan 20, 2005 | 03:34 AM
M0n0X1d3's Avatar
Question ram air or not to ram air
my 95 z28 lt1 is sportn the "98-02 ram air II" hood (http://www.carhoods.com) the hood was on there when i bought it and the 98 front clip conversion was done as well.
Who makes a ram air kit for the lt1?
Would it fit with this particular hood and front clip conversion?
and would it really be worth while (+HP wise) to dremmel out the hood scoops and install the ram air kit?
Great idea, get the dremmel and fiber glass out? -OR- Waste of time, stick with your moroso cold air intake and be happy with your fake *** hood scoops?
HELP
Thanks,
CJ
Old Jan 20, 2005 | 04:59 AM
M0n0X1d3's Avatar
Re: ram air or not to ram air
ttt
Old Jan 20, 2005 | 07:48 AM
Valkyn71's Avatar
Id say be happy with your fake *** hood scoop.
Ram air really isnt a sugnificant improvement over a CAI, if any.
It just has the cool factor
Spend the cash somewhere else for a bigger improvement.
Old Jan 20, 2005 | 10:07 AM
cmking26's Avatar
I agree keep your CAI and just have ram air for good looks.
Old Jan 20, 2005 | 10:37 AM
WS Sick's Avatar
You could convert to an LS1 style intake set-up (filter ,box,and ducting not the engine intake manifold). They flow actually better modified than a majority of the CAIs for LT1 cars.
Old Jan 20, 2005 | 10:46 AM
bdc95ta's Avatar
that hood looks hot by the way good choice.
-b
Old Jan 20, 2005 | 11:31 AM
ShawnMacAnanny's Avatar
The LT1 Ram-Air H.O and Ultra Z were the best Ram-Air setups, but i dont think they will work with your LS1 hoods. The LS1 ram air hoods had the intake snake all around. The Ram-Air H.O and Ultra Z setups were both made by SLP and it was a straight ram setup. You would see a definately gain for this. It seals off all of the air from the inside of the engine bay, and only sucks air from outside of the engine bay. The forcing of the air at higher speeds also adds a few hp.
Here is a pic of my Ram-Air H.O hood that i repaired cut out to make a single opening, cut out the water trap, and widened the opening.
http://home.earthlink.net/~3.8/siteb...ctures/hd3.jpg
A normal hood would be even. Mine took a deer at 75mph so it's the best i could do. Anyway i wouldnt put LS1 ram air on your car. I would leave the look you have now. It wouldnt be worth it except for the sound. I'm not even sure if you can use an LS1 ramair setup on an LT1, i'm sure you could with a litlte modification. Just to let you know i am paying $300 for the SLP air box kit and i have a CAI. I like the sound of Ram-Air, and being able to say i have ram-air . Also expect to see some pretty good gains with what i have done to my hood.
Old Jan 20, 2005 | 03:17 PM
M0n0X1d3's Avatar
thanks all for the info. i really appreciate it. i think i'll just keep it as is. though i can't make fun of ricers w/ fake hood scoops anymore, lol.
CJ
Old Jan 20, 2005 | 03:25 PM
That doesn't matter. Yours will always sound better than ANY ricer, and look better. May not be faster, but thats only one aspect of it. Performance, Sound, and Looks are the 3 most important things. I don't care how fast your 4 banger is, it still sounds like crap.
Old Jan 20, 2005 | 03:27 PM
zx1216's Avatar
Yea, the true "ram air" effect dosen't kick in untill you are doing well over 100mph so it's probably not worth it.
Old Jan 20, 2005 | 04:54 PM
RamAir95TA's Avatar
Old Jan 20, 2005 | 04:57 PM
zx1216's Avatar
Originally Posted by RamAir95TA
Prove me wrong then, i've seen tests and what not that show otherwise
Old Jan 20, 2005 | 04:59 PM
WS Sick's Avatar
This is true of the Stock LS1 intakes for the SS hood, but the stock LS1 set-up for the normal cars when modified by cutting the floor out of the box inthe appropriate spot and adding a highflow lid are far superior to the LT1 cais that suck from the side. With the modified LS1 box you are sucking fresh non-engine compartment air from infront of the radiator.
Old Jan 20, 2005 | 05:13 PM
RamAir95TA's Avatar
I'd like to see these so-called "tests and what-not". If you've seen them, then no one else has. People have long relied on physics and mathematical calculations to determine that these "gains" seen at speed are negligible.
Do you have wind tunnel data showing the low and high pressure frontal zones of an LT1 Z28 or WS6 simulating 100MPH and dyno results to coincide with this situation?
Not trying to start anything, but unless you have some real-world physical data...no dice.
Old Jan 20, 2005 | 06:02 PM
zx1216's Avatar
Yea, i'm not startin anything either, i thought i saw a post on advanced tech a while ago about this but i would have to look it up, maybe later i'll look into it, i'm sure it may help a bit but the performance gain isn't that great, thats all i was saying. In my book the money it would take to make it work would be better spent on other mods.
