ram air hood mod [can it be done]
I looked at a site that did a dyno test with the hood open and closed on the ramair hood for a trans am , the chart says they picked up 10.7 hp and 9 ft/lb torque with the hood open.
Does any one know if you can cut some of the hood to pick up some of this hp from more airflow. I know they have it now so it drains but can it be cut and not suck water in.
just trying to get every little free bit of hp i can, i did the thottle body bypass and the muffler bypass, and cat is there any more.
thanks
thanks
sure can, ok this is a little long but its pretty cool because they have about 20 dyno test runs with parts done.
the web site is,
www.ws6zxr.com
go to -- lt1/lt4 tec area
the post is --- links with in ...... excellent sources for lt1 info
then down to----- ws6.com mod dyno test
at the bottom of the test page it is under miscellaneous dyno runs
hope you can find all this
let me know what you think
the web site is,
www.ws6zxr.com
I cut the entire front baffle out of the hood but didnt touch the rear baffle. I dont have the ram air hooked up . I did it to get cold air in the engine bay, I do notice that if its raining hard water does get in there.
P.S. when I look into the engine compartment now through the ram air ducts I can see about a 1/2 of daylight at the rear of the hood above where the rubber seal moulding is, all the way across. Kinda like a cowl affect
When my car was still street driven, I took about 1/2" off the bottom of the front baffle (you have to reach through the "nostrils" with a flex drive on a Dremel), and about 1" off the top of the back baffle. That left some overlap between the two baffles, and it never leaked water when driving in very heavy rains.
After the car graduated to "track only", I cut both front and rear baffles completely out, and now if there is a light mist in the air and even if I'm only towing the car, it gets water in the filter panel. When I tow now, I push a big Moroso foam scoop plug in from the back to keep "stuff" out. Definitely not a good idea for a "street" driven car.
OK am I the only one that sees that on a dyno YOU ARE NOT MOVING. So your ram air is not getting air like when you are driving.
Oh well, I did notice a 1 MPH difference when I installed my home made ram air.
But that's not the question... the question is "do the hood baffles restrict air flow?" And of course that restriction will exist whether the car is moving or standing still.
Or did I miss the point of your post?
How many have dynoed with the hood closed?
When I had my one and only dyno, it never occured to me to shut the hood, since I wanted the engine to be as cool as possible.
I have the SS scam, but it probably WOULD constitute a retriction compared to open hood on a dyno.
So I guess when one claims certain dyno results, corrected, that they should also indicate hood open or closed.JMHO
F'n1996Z28SS
Aug 23, 2023 11:19 PM
