ram air
ram air
just curious. what kind of gains am i lookin at from an ss hood and air box for my z28? i want to make an ss clone. one other thing, what do you think of rachet shifters...do or dont?
Re: ram air
Do a Search on this topic, it's been debated to death. My "read" is that a cold air induction from the bottom of the car will provide colder air than the SS hood. The SS hood is more about looks than function.
Re: ram air
I agree. If you want the SS ram air set up go for it , but.............. I read the sam thing ...... That a cold air set up like the K&N or Moroso set up made more power than the SS set up. I think they said it was because of the heat with it being right on top of the intake.
I think the Firebirds made more power because the have the ram air nostrils in front on the car , thus away from the heat. If you want the hood and air box go for it, but if you want more power, from what I have read it would be better with the SS hood , to get the hood, but use a cold air induction setup.
I don't know about the power from the functional SS hood , but I have seen more than one dyno test where the cold air setup made about 19 rwhp.
Re: ram air
To begin with it's not a "cold" air set up. The air is not going to be any cooler than the ambient temp or the temp based on any source of underhood heat that affects it. So when talking about SS Scam Air v. CAI, it all depends on the routing of the intake plenum. I don't believe there is any significant difference between the temp of the SS setup than most other CAIs (which should read FAI "fresh air intake".
And I seriously doubt that either setup will net you 19 ponies, at the engine or the wheels.
In a nut shell,l the intakes are "induction" i.e., the air is not "forced" but "pulled" in by the engine. JMHO
Re: ram air
F'n1996Z28SS
Aug 23, 2023 11:19 PM
