Raising Compression?
Old Sep 4, 2005 | 10:34 PM
ChrisUlrich's Avatar
I know this is kind of a broad question but...
Lets say you have LE3 383 Setup... 6 Speed, 10 bolt.
11:1 CR puts out 430rwhp and 410rwtq.
What kind of numbers would you gain raising it to lets say... 11.8:1 or 12:1
What kind of numbers would you lose lowering it to 10.4:1 or 10:1?
I know dcr is more important, but I have no clue how that works. haha
Old Sep 4, 2005 | 10:37 PM
Jameslt1TA's Avatar
Re: Raising Compression?
I remember there being some rule of thumb...something like every point of comp is worth like 10 horse or so(just an example) i would search i know ive heard it on here before.
Old Sep 4, 2005 | 10:59 PM
turbo_Z's Avatar
People claim going from 10.5:1 to 11.0:1 will get you 2% increase in power.
BTW what you really need to be paying attention to is the DYNAMIC compression ratio.. not the static which you are asking about. Basically the more air you trap in the cylinder the higher the DCR and this is controlled by the closing point of the intake valve... typically the sooner it closes after the piston bottom dead center, the higher DCR youll see. It all has to do with the amount of AIR trapped in the cylinder instead of the physical volume of the combustion chamber... that is static CR.
Old Sep 5, 2005 | 12:04 AM
Z95m6's Avatar
Man you have no idea what you are talking about do you Brad.
Old Sep 5, 2005 | 10:46 AM
I knew that dcr was more important, but I wasn't sure if they go hand in hand. Like... having a 9:1 dcr while having a 11:1 scr. And/Or having 9:1 dcr while having a 11.8:1 scr.
And I figured it'd be easier to get an answer using the scr.
Because i'm really curious to how much power i'm gaining from the extra .8-1 on the scr.
Old Sep 5, 2005 | 02:38 PM
SStrokerAce's Avatar
Chris,
You can run anywhere from 11-12:1 compression on that setup and still have a relatively safe DCR even at the high end.
A 57-58cc chamber with flat top pistons and a zero deck block on a 383 will put you at the high end of that (12:1)
On that setup you are looking at 12hp difference from 11:1 to 12:1
Bret
Old Sep 5, 2005 | 03:46 PM
1racerdude's Avatar
It's not so much the DCR ya have now as it is the extra things that happen and ya can do with the extra static and DCR. The closer ya can keep it to the high end the more HP ya can make on pump gas or fuel.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
detroitmuscle
Jul 31, 2015 04:21 AM
Fastbird93
Jul 11, 2015 04:37 PM
