Radiatory Question for LT1 swap?
Does the reverse cooling LT1 have to have a radiator specific for that motor? I am doing the swap into an older car and was curious if I had to go find an F-body radiator or something?
The f body water pump and radiator have 3 connections each[the extra one is the 'bypass' hose]not counting the 2 heater hose connections..
Corvette[for sure] and POSSIBLY [I am not sure] Impala/Caprice LT1 pumps have only 2, so swapping the pump removes the 'extra' bypass hose connection...
Not sure what you would do with the steam/vent hose that connects to the radiator just below the filler cap though..
Jul 4, 2005 05:00 PM
