Radiator support structural integrity
Old Oct 29, 2004 | 09:47 AM
Rodrigues's Avatar
On where the radiator cover goes on the front of the car. How important is this to the actual strength of the front end? Would something like a STB compensate for the strength losses from cutting this off? Or would a bar be neccisary in order to restore the strength lost?
Old Oct 29, 2004 | 10:17 AM
ChrisS95TA's Avatar
Re: Radiator support structural integrity
Well, my car was hit in the front drivers side and the support was broken where it connects to the bumper cover. I rigged it up to give it support otherwise it noticably sags. I do not think the actual support can be removed without sagging, only the reinforcements which if removed will cause a low speed accident to look like a high speed accident if you are hit
Old Oct 29, 2004 | 05:19 PM
Depends on exactly what part you are referring to. There is a piece that bolts in that holds the headlights, but the part behind that is a structural part of the unibody. I wouldn't be removing that.
68camaroboltz
Oct 5, 2015 01:46 PM
navtool.com
Sep 24, 2015 03:30 PM
navtool.com
Sep 24, 2015 03:26 PM
navtool.com
Middle Atlantic
Sep 24, 2015 03:17 PM
Pwilson59
Sep 3, 2015 08:47 PM
