radiator questions
Old Dec 29, 2003 | 06:29 PM
kingman109's Avatar
radiator questions
okay radiator was bad in my totaled camaro... rebuilt everything and put in a used one.. well tonight i started up for first time and not quite sure if antifreeze is going through engine... she runs good... and the radiator is getting pressure.
how long till the engine temp gauge should start rising at idle?
and any reason why low coolant light staying on....?
Old Dec 29, 2003 | 09:05 PM
$hawn's Avatar
If it's just idling it might take 5-10mins. before the gauge moves, and the low coolant light, you prolly need more coolant once the thermostat opens, after that and it's still on, the sensor is more than likely bad.
calaban
May 18, 2020 06:43 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
grgguy
17
Feb 23, 2015 07:57 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
