Radiator Hose
Old Aug 31, 2004 | 09:14 PM
SantaCruz163's Avatar
Radiator Hose
Is it alright that when my engine is cold the top radiator hose is collapsed? It's like there is a suction making it like that? I don't have any problems over heating and all the air is out of my system (that I know of) because when the engine is warm I open the bleeder and just a stream of coolant comes out. So my question is, do I have a problem with my hose like this? Also, my 'low coolant' light came on a few days ago so I added some mix to the overflow tank and didn't think twice about it since I wasn't having any problems. Today the light came on again, but still no problems. What would you suggest? Pull the sensor and clean it maybe? Before the weather cools down I plan of a complete system flush anyways.
Old Aug 31, 2004 | 09:32 PM
OBE1 95Z28's Avatar
Re: Radiator Hose
I would remove the radiator cap when the engine is cold and verify that the coolant is to the top of the radiator. If it's not, you need to add coolant and properly burp the system. If the level is too the top, it sounds like your coolant level sensor is dirty or faulty.
I don't recall ever seeing any of my radiator hoses collapsed.
Old Aug 31, 2004 | 10:05 PM
Re: Radiator Hose
Hoses should really not collapse. Maybe you have a bad radiator cap. It has a vacuum relief so that during cool down it can pull coolant from the remote reservoir if needed.
Old Aug 31, 2004 | 11:09 PM
Re: Radiator Hose
Well I just checked and sure enough I was a little low in the radiator. I added water for just for now, like I said I'll be doing a complete flush soon. Tomorrow, since I don't feel liek waking my neighbors I will bleed the system again. Hopefully that does it.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
