Rad Hoses
I know that good year is pretty good... They are usually used in police packages.... But they dont make it for the 93' camaro only 94'-97... The rad hoses are different....
Summit part # GTR-5006.....
If you got the money and time you could make them out of braided.. They are the strongest....
93Z Will
93Z Will
Goodyear Hi Miler set is good [except that one hose is missing! but that can be worked around]
It has 10 of the 11 hoses...
While it is for the 95-7 configuration, you can change a 93-4 to the later hoses, with the kit, [and you also need the 95-7 'bleeder pipe' as opposed to the 93-4 'bleeder tee']
I did it on my 94... gets rid of that funny molded tee on the drivers side radiator hose, also it allows getting rid of the 'coupling' needed for 93-4 TB bypass...
A bit tricky to do but I felt that a 94 was 'ready' for all hoses to be replaced..
The kit even has all [except ONE that is!]of the heater hoses[ you replace those by Dremeling off the crimped clamps]
Charlie
Charlie
www.earlsperformance.com for braided
