Quickest/Easiest way to bleed brakes?
Old Jul 9, 2003 | 09:47 PM
JD30thZ28's Avatar
What is the quickest and easiest way to bleed the brakes?
I was mocking up my line lock kit lines and had to pull off my front brake line from the ABS unit and now I have no pressure in my brake pedal, what would be the quickest and easiest way to bleed them. Thanks
Old Jul 10, 2003 | 08:44 AM
All_Z_Way's Avatar
The typical way to bleed is to start at the farthest wheel from the master cylinder and work you way to the closest wheel to the master cylinder.
You will need some one to pump up the brake and hold it while you release the bleeder valve. Do this on each wheel til' no bubbles are visible in the fluid.
There is a bleeder on the ABS unit also, but I have never had to mess with it before.
Formula Steve
Sep 19, 2023 08:31 AM
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
1bad427ls1
Sep 23, 2015 01:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
