Quick turn signal problem
Old Feb 9, 2004 | 03:47 PM
1996 | Z28 SS's Avatar
When I signal left.. the blinker doesn't blink.. just stays on. Same with the actualy lights (front and rear) They just come on but don't blink. What do I need to do to fix it? Is it a fuse or something? Thanks!
Old Feb 9, 2004 | 04:07 PM
Most likely you have a burned out element in one of the bulbs. Look closely at them and compare to the other side.
Old Feb 9, 2004 | 04:08 PM
Brandon95TA's Avatar
Just a question for you, do you happen to have the Sequential turn signal mod done? I did it a year ago and after about 6 months that happened to me, I had to get new sequencers and everything worked perfectly fine again. If you haven't done that, then I can't be of much help sorry.
Old Feb 9, 2004 | 04:19 PM
Nope... sorry don't have the sequential turn signals..
I'll wait untill it gets a bit darker to compair the lights... thanks guys!
Old Feb 9, 2004 | 04:58 PM
Ok.. I just checked my lights again... the rear is fine but the front left turn signal light (amber one) is completely shot. It doesn't come on at all. Do I just need to replace it and then I should be fine? Thanks
Old Feb 9, 2004 | 05:02 PM
A new bulb shoud fix you up.
Old Feb 9, 2004 | 05:10 PM
Awesome.. thanks shoebox
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
formula79
26
Aug 5, 2002 12:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
