Quick question re: water pump install (pics inside)
Old Apr 23, 2006 | 03:57 PM
Rising Phoenix's Avatar
I'm in the middle of doing a water pump replacement on my '95 Z28. I have gotten everything apart and the old pump off, and I noticed that there is a piece stuck on the "drive shaft" of the old water pump, that looks like it is used to connect the water pump shaft to the shaft that comes out of the block.
I'm assuming I'm supposed to pull that "adapter" piece off, and put it on the new water pump, but I can't get that piece off of the old one. It's on there really good. Am I on the right track, and if so, how do I get it off and onto the new pump?
Pic of the old pump with the piece attached to the shaft, note the missing ball bearings :
Pic of the new pump, without that piece:
Please help ASAP!
Old Apr 23, 2006 | 04:03 PM
v8pwrdz28's Avatar
Re: Quick question re: water pump install (pics inside)
u need that shaft yes, it is what drives the pump. it is most likely just frozen on the old pump, shoot some PB Blaster on it and u should be able to get it off of there. might have to beat on it a lil bit to get it off.
Old Apr 23, 2006 | 04:07 PM
OBE1 95Z28's Avatar
As stated above you need that shaft. The new water pump should have come with small 2 O-rings; they go on the end of each splined shaft (engine side and water pump side) and the small shaft slides over the splines and the O-rings keep crude out of the shaft.
Old Apr 23, 2006 | 04:10 PM
96ZCamaro's Avatar
Just use a hammer and everything will be cool
Old Apr 23, 2006 | 05:03 PM
Ugh, of course my water pump didn't come with the O-rings and I know when I take it back to Checker, they'll go "I don't know about any O-rings!"
Old Apr 23, 2006 | 05:47 PM
OBE1 95Z28's Avatar
Look at your existing O-rings; if they look OK, just reuse them. The O-rings only keep dirt out.
Old Apr 23, 2006 | 09:12 PM
Jeff95TA's Avatar
The o-rings are cheap if you can't reuse them. Part #12553792
Old Apr 24, 2006 | 09:33 AM
Bump.
I'm taking a break from the job for now but I tried some PB blaster on the shaft and it's still really stuck. I've only tried pulling by hand and prying with a screwdriver though, are there any other ideas I can try for removing the little [explitive]?
Old Apr 24, 2006 | 10:34 AM
94EvilZ28's Avatar
Heat that thing up then try prying it out...see if that helps...heating it up should help...it did with mine.
Old Apr 24, 2006 | 12:30 PM
Chuckels's Avatar
Put a set of vice grips on it close to the bottem then use a pry bar on the vice grips.
Old Apr 24, 2006 | 12:53 PM
raxxus's Avatar
I had to use vice grips myself and had to get new o-rings.
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
