Quick Question On pluggin cam drive
Old May 27, 2008 | 06:11 PM
TAEnvy's Avatar
Hey guys im in the middle of a cam swap and im stick. Im running an EWP and I converted to a double roller so I need to block of the hole in the timing cover which im going to do a freeze plug and jb weld but what about the hole in the block where the gear used to go, does it need to be blocked off to?
Thanks guys
Old May 27, 2008 | 07:04 PM
Stl94LT1's Avatar
No need to plug the hole in the block.
Old May 27, 2008 | 07:06 PM
johnnyb's Avatar
you'll get mixed opinions on this. you could leave it unplugged and be fine... just more oil on timing chain. Some people say that not plugging it though will drop your oil pressure. I plugged mine cause it took less than 5 minutes.
Old May 27, 2008 | 07:54 PM
evilundisguised's Avatar
Thanks guys
I blocked mine off because I had an extra freeze plug (1.25") and figured it'd keep oil moving in the same fashion as the stock setup (not through the bearing).
I used a 1.25" disc-style plug, staked in 3 spots around the edge so it doesn't wiggle out and sealed up with RTV gasket-maker.
Old May 27, 2008 | 08:23 PM
mdacton's Avatar
How would it change oil pressure? no pressure goes to it.
I wouldn't waste my time pugging it......it will be fine
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Noenav
Mar 1, 2019 07:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
