Quick Question! Help Asap
Old Mar 28, 2004 | 11:38 AM
Cmr0z28's Avatar
I was told I don't need to block off the EGR tube on the back of the intake manifold? The valve is in place, w/no vacuum to it and the solenoid unplugged. Is it going to get air in there if I don't block off the connection from the manifold?
Old Mar 28, 2004 | 11:59 AM
ibanez6rg's Avatar
I'd say just get some aluminum or cut a pop can the same size as the tube. Put it on the intake and then the tube, bolt it up and now it's blocked off.
Old Mar 28, 2004 | 01:00 PM
Cmr0z28's Avatar
Ok, but the question is, will air get into the intake manifold if I leave it opened, and the valve stays in place and stays closed?
Old Mar 28, 2004 | 02:04 PM
Mtrhds94Z's Avatar
Provided the EGR isn't clogged or stuck open, it is normally closed..
With the vacuum hose off it, it won't open..
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
Brake_L8
Jan 20, 2015 09:44 AM
