Quick Question - Have to drain coolant before pulling heads?
Old Nov 23, 2004 | 08:58 PM
96_pimped_out's Avatar
I just got the last bolt out of the bottom side of one of my heads and it was spewing a lot more coolant than I expected. Should I drain the entire radiator before pulling the bolts out, or is ok to just let the heads bleed out some when you pull them and leave the radiator alone?
I just didn't want to sit there and try to catch 3 gallons coming out of a bolt hole all night or drain the radiator of almost new coolant for no reason.
Thanks,
Craig
Old Nov 23, 2004 | 10:45 PM
Mike383LT1's Avatar
Re: Quick Question - Have to drain coolant before pulling heads?
the easiest way i found was to drain the radiator then pull the knock sensor found on the pass. side of the engine block i made the mistake of just draining the radiator but there is still a fair amount of coolant in the block
Old Nov 24, 2004 | 09:22 AM
Thanks Mike... I did that too and caught a little more but unfortunately it had already drained most of it and ended up in my garage floor.
Thanks for the reply!
calaban
May 18, 2020 06:43 PM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
Brad 97z
Aug 10, 2002 09:58 AM
