quick question about ebay air intake
Just wondering if anybody sees any problems with this short ram air intake setup i found on ebay.
http://cgi.ebay.com/ebaymotors/93-97...7158QQtcZphoto |
Re: quick question about ebay air intake
The difference between that intake and most of the commercially made ones is just the location. That intake will leave the filter sitting up in the engine compartment, while the commercial ones usually relocate it all the way down into the "air box". The commercial intakes also usually include a block off plate.
Probably no difference in actual performance though :P |
I've got the same thing on my car (also purchased on ebay). It adds good power but you get what you pay for. When mine arrived the air filter was bained up and the air intake tube wasn't perfectly round (the tube was also filled with shavings from when it was cut, so make sure you clean it thoroughly). Something I also noticed is that with the screen at the end of the filter is basically where all of the air gets sucked through. This is because the filter is so restrictive and the screen doesn't catch a whole lot. So, if you do choose to go with that kit I highly recommend you don't use the provided filter otherwise you may get debris in your engine.
thanks for the info, there is another kit that uses a k & n for around 35$ so i will go with that instead
yeah $35 plus how much shipping?
Those filters are total crap. Get a real K&N filter or stick with your stock air box and a FRAM filter. I got shavings in my motor 6 months after installing one of those cheap filters. the tube looks ok.
There are other kits on ebay which include that pipe + a peice of straight pipe which will put the filter inside the fender well (where you want it), and it comes w/ a k&n cone for like $100.
Just for ****s and giggles, I ordered a similar CAI for my Expedition a few months ago. It was ~$15.00 plus ~$30.00 shipping. :rolleyes:
Well... You definetely get what you pay for. Even though the box had a label that it is for "97-02 5.4L F150/Expedition", there was no way in hell that thing would even remotely be suitable for that application. The seller stated in the description that "professional installation is recommended" and "we do not provide any service", so when I sent them the pics trying to installa it, they just said "too bad, get professional help, no refund" etc. Filed a complaint with Paypal and after a few weeks got all my money back. I was out of shipping it back to them, though. All in all: don't expect much. :blah: I'd suggest saving a few more bucks and getting a "real" CAI (K&N, Moroso, GMPP etc.) instead. You'll be much happier if you did. Sorry for the long rambling... TS |
The "stage 2" intake has pics of it installed on an F-Body. It has the second tube dropping it out of the engine bay.
Pretty simple device since it just makes one turn and then goes down into the fender. I would make sure you get the one with the K&N Filter. |
