Quick Question
Old Nov 14, 2003 | 12:52 AM
Camaroz28lt1383's Avatar
Quick Question
I just got done putting the car together, and I went to hook up the battery terminals, and when I put the 2nd one on, the car tries to start itself, what could be wrong here? Thanks Paul
Old Nov 14, 2003 | 01:15 AM
ttt
Old Nov 14, 2003 | 02:42 AM
93formula's Avatar
what the car wants to start???!!!! are you hooking up the starter cable to the battery some how? does this happen when you put the ground cable on or the positive? im guessing you have your cables reversed from your starter to your battery some how.
Old Nov 14, 2003 | 03:00 AM
Prorac1's Avatar
relax gang. Its either a defective ignition switch (not likely since you just had the car apart) or the starter is shorting out on its self internally. The other option (and the most likely one) is that you hooked the wires up wrong and the hot wire is hooked to the crank post on the battery. no biggie. Prorac1
Old Nov 14, 2003 | 07:47 PM
$hawn's Avatar
Make sure the metal terminal on the purple starter wire isnt touching the one on the big black starter wire.
93formula's Avatar
so what was it?
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
