Quick OTVC Wires question....
Old Mar 21, 2008 | 04:28 PM
96supersport's Avatar
I tried searching but no body has the same headers as me so i figured i would ask here.
Ok i have Edlebrock prototype shorties, on the drives side, the headers come up almost level with the valve cover then they go down to the cat.
I wanna know what you guys think before i buy these wires.
(should i just run cool socks on that side?)
Old Mar 21, 2008 | 04:56 PM
ssbowtie1's Avatar
With shorties (especially on a dual cat car) it might be better to just run the wires in the stock location.
Can you post up some pictures showing clearance?
Old Mar 21, 2008 | 07:49 PM
caldercay's Avatar
I have an idea how the primary pipes are routed, but without a photo, it's
going to be difficult to be sure. However, based on what I've seen, you
will probably want to route that side "lower" - bring the wires across from
underneath - it wont make sense to route them across the valve covers
and then try to figure out how to get them over the primaries.
Old Mar 21, 2008 | 10:20 PM
the it almost looks like i should run the stock style on the drivers side and ovtc on the passengers side
the drivers side header comes up and looks kinda like a "tuned length" header
the passenger side looks like a long tube that someone cut short
Old Mar 22, 2008 | 10:15 AM
2000GTP's Avatar
Generally, with shorties, stock routing is preferred. I'm not sure what the "prototypes" involve, but it sounds like it you bought the do it yourself kit and cut/crimped your own wires, it would be your best bet.
Old Mar 22, 2008 | 10:21 AM
Hybrid86Z's Avatar
yep
ShwaZedder
Apr 20, 2015 02:31 PM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
