QUICK Help Please, Removing Oil Cooler?
Old Jun 13, 2003 | 10:36 AM
AENIMA95z28's Avatar
I wanna mess nuthin up, whats the best way to remove this oil cooler or at least clean in, im kinda in the process of changin oil now and i decided i should clean it. Please help
Old Jun 13, 2003 | 11:41 AM
cmon guys, im in a jam here
Old Jun 13, 2003 | 12:12 PM
badblackz's Avatar
I just removed the lines to get at my oil pan bolts. The lines are held on to the housing by one bolt. It was a pita to get that bolt loose. Then they just came right off, but be careful because there are seals for each tube that can rip.
Old Jun 13, 2003 | 12:15 PM
badblackz's Avatar
oh yeah there is also a nut on the front driver side oil pan stud that holds them in place. Then just unclamp your hoses.
Old Jun 13, 2003 | 12:26 PM
ok thanks man, i cleaned it out with engine degreaser then washed out with water then dried with a dryer, sound ok ?
Old Jun 13, 2003 | 12:31 PM
Rodrigues's Avatar
Why don't you just remove it? I didn't notice any difference in running temperatures and its not needed.
Old Jun 13, 2003 | 12:36 PM
chasmanz28's Avatar
yes sounds good, let us know how much diffrence there is on the oil pressure when you get it all completed
Old Jun 13, 2003 | 12:38 PM
mobleman's Avatar
Same here. Rodrigues, did you notice a change in your oil pressure after removing the cooler?
Old Jun 13, 2003 | 01:51 PM
ok if you remove it what do you screw your oil filter into, when i pulled off the cooler there were two shafts sticking down along with the cooler input shaft that prohibited my oil filter from screwing on.
Old Jun 13, 2003 | 01:52 PM
o yeah if i knew how to get that filter on i would have, o yeah the oil cooler itself was an upgrade from the dealership, allot of 95 camaros and transams didnt even come with them
Old Jun 13, 2003 | 02:47 PM
Rodrigues's Avatar
You need two 5/16-18 1" bolts to replace the studs...
BigWil
Mar 29, 2015 12:24 PM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
97SSdude
Dec 31, 2014 07:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
97 RedSS
Jun 10, 2003 07:58 PM
