Quick Coolant Bleeding Question.
Old Aug 18, 2003 | 02:12 AM
S8ER95Z's Avatar
Ive had to rebleed my system too many times now..and I have a simple question. Every says to crack the bleeders then fill up until you have no air. Well thats easy with the T-stat bleeder. Then I close it off and proceed to fill it up.. however the bypass tube from the T-stat to radiator (the other bleeder) is above the fill mark on the radiator..so technically I can never get all the air out. Is it just my system/?? Any secret tips for this? Im a bit confused.
Thanks again to Shoebox for pic.
Old Aug 18, 2003 | 02:16 AM
blueirocz-28's Avatar
i always crack them both open when filling. then close off the thermostat bleeder and leave the bypass open, then i put the cap on the radiator and start the car, close the bleeder when it stops spittin air.
Old Aug 18, 2003 | 03:53 PM
S8ER95Z's Avatar
Thanks.. Ive tried it a few ways with the car running..but I alwasy screw up and get air in..Ill try that way and see what happens.
Aug 7, 2015 01:26 PM
MikeWhitener
Aug 2, 2015 06:17 PM
techstar
Jul 31, 2015 11:27 PM
Latronaxe
Jul 20, 2015 12:00 PM
Noct
Jul 14, 2015 01:18 AM
