Quick Coil Wire Question
Old May 21, 2007 | 02:26 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I need to order a coil wire today or tomorrow. Are the coil wires for a stock LT1 setup female/female, male/female or male/male? Based on the appearance of the coil, I'm assuming at least one end is female. I called Summit and the guy I spoke to gave me a part number for an MSD that is male/male and I don't believe that's correct.
Thanks.
Old May 21, 2007 | 04:37 PM
93-95 has coil wire with an opti boot/connector on one end and a normal, right angle plug wire end looking boot/connector on the other. I would consider that male/female.
96-97 has an opti type boot/connector on both ends. I would consider that male/male.
Old May 21, 2007 | 04:47 PM
BTC's Avatar
BTC
Thanks. I owe you a donation.
So an MSD 84049, that part number might be specific to Summit, female/female with 90 degree boots wouldn't work? Maybe I'll just order a new stock wire from Jason. An aftermarket wire may not offer any benefit anyway. I'm going to replace the stock coil, so I thought I would get an MSD wire from the same place.
Old May 21, 2007 | 04:58 PM
BTC's Avatar
BTC
I called MSD and got an answer to my question. I guess they don't make a direct replacement coil wire for an LT1 and if they do it's not sold individually but rather as part of an entire wire replacement kit.
Old May 21, 2007 | 06:53 PM
I believe if you order a full set of plug wires, it comes with both types of LT1 coil wires. You just use the one you need.
Old May 21, 2007 | 08:31 PM
BTC's Avatar
BTC
That's correct. The part numbers MSD gave me were 32143 or 32149 depending upon whether you want red or black wires. I just ordered a new stock coil wire. I'm planning to do headers at some point and wasn't sure whether those MSD wires would be what I wanted when I do get around to changing my plugs & wires and I didn't feel like dropping 100 bucks just to get a new coil wire. It sounds like most people go over the valve cover with headers and I doubt those wires would work for that application.
Old May 21, 2007 | 08:51 PM
Munson's Avatar
i just did my plugs today.. with msd wires which wire do you need?
Old May 21, 2007 | 08:54 PM
sbs's Avatar
sbs
Just find somebody who bought the MSD set and has the opposite type you need and buy the spare from them.
Old May 21, 2007 | 08:56 PM
Munson's Avatar
yeah, i have one for a 93-95. Just pm me if you need it.
Old May 21, 2007 | 10:17 PM
BTC's Avatar
BTC
That is the year I need, but I guess it's too late as I've already ordered a stock replacement. I would be willing to put a sticker on my car stating Coil Wire Supplied By Munson if the price is right.
Ari G
Dec 11, 2014 03:21 PM
lbrowne
Nov 13, 2011 04:25 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
kandied91z
Aug 6, 2002 01:18 AM
