Quick clutch ??
Old Nov 14, 2014 | 08:05 AM
BradZ28's Avatar
Quick clutch ??
Hey all, I finally need a new clutch after 14 years of abuse. I did a search and found that most were buying the autozone kit for the pressure plate and alignment tool, and buying an aftermarket disk. Is this still true, and which companies will currently sell just a disk? I think I'm going to have the stock flywheel resurfaced. Thanks!
Brad
Old Nov 14, 2014 | 10:00 AM
RUDEDOG's Avatar
Re: Quick clutch ??
There are several. Check Summit Racing.
Old Nov 21, 2014 | 12:55 PM
Chimera96's Avatar
Re: Quick clutch ??
McLeod makes a DF disc which for your H/C car would work better than a stock organic disc
All clutch companies use the same china clone PP for the LT1 so just buy the AZ kit and buy the McLeod disc. $175 for disc IIRC
or maybe one of the clutch companies has a sale making their LT1 kit with a DF disc cheaper. Competition Clutch 2500 was $300. Not endorsing it but that may be the cheapest if you want a DF disc
Old Nov 21, 2014 | 02:51 PM
timnfxr's Avatar
Re: Quick clutch ??
Which components you get, it's recommended that you get the flywheel and pressure plate balanced.
mmf_1013
Sep 12, 2015 08:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
