Quick Bleeding question, fast awnser plz
Here.. Learn from my stupid mistakes... Do it with the car in a perfectly horizontal surface if you are using the bleeder screw at the radiator..
I attempted it with the car in a very slight incline... not even half of the coolant came out. I am glad nobody was watchin..
I didnt raise the front... just got my arm unserneath it... and loosed up the screw. This time I got smart and turned the car the other way. Oh yes I filled her up with water before I cranked her up off course
Then I undid the screw again and this time she empty herself out. its a funny feeling when all tha coolant runs down your arm to your armpit....
So be careful. I am glad my engine wasnt up to operating temp when I un-screwd that bolt thing..... get my point?
Marvin
So be careful. I am glad my engine wasnt up to operating temp when I un-screwd that bolt thing..... get my point?Marvin
yeah
i got it done, its all done and done. Thanks for the help, was installing a 160* tstat soo. Seems to have bled out good, just hope i didnt get coolant on my opti. ALOT more coolant came out the tstat housing the expected
cross your fingers for me
Originally posted by Coop1
Can someone explaing how you are supposed to bleed the cooling system? I am about to change out my weeping waterpump before it explodes all over my opti.
i gotta new ? say i just got done driving around n such, and i go to bleed it again. But i have the car off and crack the bleeder and hear eitehr air going in or comming out
and close it real fast... which was it? air in or air out?
radiator full, and if anything i have too much in the resivoir.. Also haha should the liquid come out Pure (meaning 0 bubbles in it) when i bleed the line (the one with the screw driver not the one on the tstat) it comes out somewhat foamy Is that cuz i have the valve just cracked open or is that still air excaping the system
Mine gave me all kinda **** trying to get it working with out air in it. It should take about 4 gallons, yet ine only ate up (BARELY) 3. The engine sat since 96 empty and i didnt no the conditions of the cooling system, but anyways ...
When i filled up the radiator, i had both the bleeders open ( And a rag over the Opti for good measure ) I filled it to the fill neck in the rad. Not a SINGLE drop came out of eitehr bleeder. I waited 2 mins, checked the fluid, same posistion. So i had to actually blow water through the lines ( 5-10 PSI from a compressor with a rag around the air tip blowing into the radiator filler cap. Then antifreeze bubbled out of the bleeders, and then a steady stream, so i cosed both, then checked, it was a hiar low in the rad. I toped it off, filled the overflow resivoir to the correct spot as well. After i ran the car for about 20 mins at idle ( To get the T-Stat open. ) I let the car cool, and added about half a quart more of antifreeze. I ran it again till it opened, let it cool completely ( Next morning ) and added a little bit more. For some reason my system took a **** when trying to fill/flush it. I cant figure it out, so i jsut kept an eye on the temp the past few times ive run it and check the fluid for a few times ... If you have this problem, there really isnt a solution that i could come up with, so jsut keep a good look over things for the first few openings of the Tstat to make sure all the air is out of the system.
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Feb 15, 2015 07:49 AM
