Quick battery question...
Old Jul 9, 2005 | 05:05 PM
  #16
94zgreenmachine's Avatar
Re: Quick battery question...
Originally Posted by Silvershark
My battery voltage now goes down to 7.1 volts while cranking. It defiantly is better, but not correct.
Sounds like you got a dead cell. Did wally world put a load to the battery when they tested it? I had a battery that registered 12 volts but when a load was put to the battery volts went to 6. If the cell is dead it is toast. Willin' to bet thats your problem.
Old Jul 9, 2005 | 06:07 PM
  #17
Silvershark's Avatar
Ok it goes to 8.8 now and wont die while trying to turn it over... It just wont turn the engine over... I have a SES light before starting, ABS INOP and a Check Gauges light that is very dim. I found some 1/8" connectors that go in the back of the block for my oil pressure gauge. It now reads 0 when the key is in the on position. It will climb up to about 40psi when I try to start it and then the oil pressure on the gauge will go back down to 0 within 10 seconds.
I am lost..... I thought the oil pressure gauge was supposed to go up as soon as you turned the key to the on position...
*Edit* Oh yah, I had the wrong oil sensor too... Now that the correct sensor is plugged in the oil thing seems to be working much better now.
Formula Steve
Sep 19, 2023 08:31 AM
Quickss96
Jan 29, 2016 05:56 PM
weedog
Aug 15, 2015 08:23 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
