Questions about SLP's CAI
Old May 6, 2005 | 01:22 PM
crazypurgatory's Avatar
Question Questions about SLP's CAI
I got a SLP CAI off one of the members of the board.
And am very happy with it.
Just wish my car was not damaged on the side that the CAI goes on.
Previous owner wreck the car and fixed the out side but not the inside corner .
My question is this has the SLP CAI always been made from stainless steel?
Because the one I have some body painted it and I would like to Polish it if it's stainless steel.
And I see some SLP CAI's have a mouting tab to mount it to the radiator support.
So is there a new design and a old one?
Thanks,
Chris.
Old May 6, 2005 | 01:28 PM
psychocabbage's Avatar
Re: Questions about SLP's CAI
older design.. one of the first CAI setups for LT1.. I used to have it and loved it.. regardless of the finish, unless you really like to undo all the AIR unit it will get scratched when you install or remove it..
at the track, its good to throw ice bags on it and on the intake manifold.. netted me .3 in my 1/4 mile trips.. so well worth it..
From the factory the SLP CAI is black powder coated.. the same unit was sold through GMPP and its finish was polished stainless steel (it was also $100 more than the SLP unit)..
the mounting tab is supposed to be there.. has always been..
be happy.. SLP CAI is much better than those plastic ones.. it will retain the cold from the ice at the tracks better..
if someone tells you garbage about heatsoak, drive for however long you want, pop your hood and feel the CAI tubes.. Mine were never even warm on hot houston days driving for over 2 hours..
Old May 6, 2005 | 02:47 PM
bt96ss's Avatar
I had one and loved it. My only complaint is you have to remove the filters from the bottom to remove the tube. I switched to Moroso because it has a plate that separates the filter and tube. I felt no sotp change between the two. SLP was better looking though.
Old May 6, 2005 | 02:58 PM
Question Re: Questions about SLP's CAI
Well is it made from stainless steel?
I guess for some reason sombody took the mouting tab off.
Thanks,
Chris.
Old May 6, 2005 | 05:39 PM
foxbat's Avatar
my SLP has a block off plate between filters and tubes....maybe older versions didn't have it?
Old May 6, 2005 | 05:59 PM
Yea I have to buy the filters and the block off plate.
So I will ask them if I can get the mouting tab for it.
So does anybody know if it's made from stainless steel?
Thanks,
Chris.
Old May 6, 2005 | 07:47 PM
hatredizm's Avatar
Is this the SLP CAI that has the small dual filters?
Old May 6, 2005 | 08:08 PM
Lightbulb Re: Questions about SLP's CAI
Yep sure is.
Chris.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
alex5366
Feb 17, 2015 09:07 AM
Kyle@SLP
Jan 7, 2015 02:09 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Brad 97z
Aug 10, 2002 09:58 AM
